VStar 250 owner on a quest
Introduce Yourself
  • This topic has 2 replies, 3 voices, and was last updated 15 years, 10 months ago by Munch.
  • December 11, 2010 at 9:45 pm #4292
    KDBunch
    Hello interwebs. My name is Kevin, and I own an ’07 Yamaha V-Star (Virago… whatever). I have a couple problems with this motorcycle. It seems as though I am having fuel system issues. More than a couple times this bike will quit on me when I clearly have fuel remaining. When this happens it is drastically fast. So fast that I don’t get a chance to switch over to reserve and am forced to pull of in a neutral coast (unsafe feeling) and wait a second so that some fuel has a chance to trickle in to start her up again and quickly switch to reserve before it dies.
    Issue two: during the end of this last riding season here in Northern Nevada, I had to drop the clutch to get the bike started a couple times. This is not a battery or starter problem from what I can tell. My conclusion at this point is to blame it all on a vacuum problem with the fuel system. My dad, mechanic, seems to think that fuel may be filling up in the cylinders while the bike is not in use making it too difficult for the starter to turn over the engine. When I drop the clutch the hypothesis is that the fuel clears from the cylinders and presto, motor on.
    The vacuum problem may be the culprit in each of the infamous issues with my bike since fuel isn’t being used efficiently, it dies with even a quarter of a tank left, and there isn’t a strong enough vacuum to keep the fuel from leaking into the engine while not in use. Am I missing something? What are your thoughts?
    December 17, 2010 at 12:23 pm #28936
    Munch is your best bet on getting an answer to a mechanical question on this forum.
    December 18, 2010 at 4:17 pm #28939
    :^) thanks for the props… .but luckily we also have Trials on here to that has quite the knack for the bikes. I believe this one got an answer in another section that he had posted in .
    Let us know if you got it figured out KDB. Nothing worse then asking for help then not following up on what the actual fix is/was. Share the wealth…you might just be helping someone else in the same situation.
