Rust on used bikes
Rust on used bikes
  • This topic has 8 replies, 3 voices, and was last updated 18 years, 2 months ago by acidpope.
Rust on used bikes
  • June 27, 2008 at 5:42 am #1614
    Looking at used bikes online and some of them have varying amounts of rust on the bottom of the bike or on the exhaust. Is that a sign of a poorly maintained bike or that it was stored outside. All bikes are 2000 or newer.
    June 27, 2008 at 9:58 pm #7987
    acidpope
    2000 or newer I’d say poorly maintained.
    June 28, 2008 at 5:11 am #7998
    What about some rust on the chain? Would the chain need replacing?
    June 29, 2008 at 12:08 am #8024
    acidpope
    You can try using kerosene and a brush to remove the rust. Mind you it’s messy, and you need to wear gloves while using it and cover the other parts of the bike that might get kerosene on it if you do it while it’s on the bike. Some people use WD-40, but this can and does damage your chain after prolonged use. You can see what it will do here (scroll down to the update):
    http://www.webbikeworld.com/t2/motorcycle-chain-lube/
    Or you could just buy a new chain.
    June 29, 2008 at 12:15 am #8026
    I’ve heard mixed claims on wd-40 on O-ring chains. Some people claim no negative affects what so ever. I prefer to do it the way it’s been done with kerosene though…
    As far as them commercial dual clean/lube chain mabobbers, I’ve heard they’re not very effective. YMMV, just relaying the things I’ve heard…
    June 29, 2008 at 2:17 am #8036
    bam37
    rust on chain=bad maintained…use Chain wax once a week
    June 29, 2008 at 12:13 pm #8046
    Josh
    so kerosene and wd-40 can be used to remove rust, but is there anything you can use to prevent it on a new bike? Rust is a concern of mine, I would like as little as possible on my new EX250R. I know storage is probably a big factor in rust prevention. Unfortunately I do not have a garage to keep it in as a I live in an apartment, but I do keep it under a porch with a good quality cover on the bike at all times so its really not getting any water directly on it. During the winter it will be stored in the basement covered as well, I cannot keep it in there normally just because its going to be tough getting it in there once a year, never mind daily.
    June 29, 2008 at 3:18 pm #8052
    bam37
    use chain wax, it should help prevent rust, as well as stretching of the chain.
    June 29, 2008 at 6:31 pm #8057
    acidpope
    Chain cleaning video up in the video forum.
