- This topic has 1 reply, 2 voices, and was last updated 16 years, 9 months ago by
Ixecapade.
Problems starting 97 gs500e
February 5, 2010 at 3:28 am #3693
loveme2times
Participantthis summer i purchased a 1997 suzuki gs500e from my older brother and ran into a few problems. first was a fuel line issue that i thought to be resolved. the bike would have an inconsistency in the throttle spiking the rpms way higher than intended instead of a smooth acceleration. After that was fixed i actually got myself into an accident being a wreckless teenager… Anyways to the most recent problem, today I went to try to start my bike and it wouldn’t turn over so i thought charging the battery made sense but even after that it still would not start so i resorted to push starting it wich actually did work and then rode it around for a while, while it was running i turned it off and tried to start it back up again and it wouldnt work without giving it the right amount of gas and in a later attempt the bike would not start at all. can anyone tell me what the problem could be?
February 5, 2010 at 2:47 pm #24417Ixecapade
Participantyour battery might be tapped- my roommates would charge but it didn’t have enough ump to turn the bike over… replaced the battery and voila no issues starting. Speaking of which I gotta go crank her’s today before we get plastered with snow.
psat that make sure your choke is adjusted properly…
and carbs get gummed up especially if you have a fuel issue.
past that- I got nothing
I just remember those are the issues we covered with her bike. Good luck!
