Ninja 650r vs Ninja ZX6
  • This topic has 5 replies, 3 voices, and was last updated 18 years, 4 months ago by StarfoxXIII.
  • July 4, 2008 at 4:25 pm #1666
    StarfoxXIII
    I’m just started looking at bikes im going to get one next summer when I pay my truck off. I’m planning on getting the 650r. I’m just trying to suck up as much info as possible now on all bikes. But heres my question? When looking at top speed, quarter miles, and 0-60. These bike look almost identical. So why is the Zx-6 such a more aggressive bike besides sitting position.
    I know that one has a inline4 engine and the other has a parallel twin just wondering what makes one so much stronger then the other
    July 4, 2008 at 8:09 pm #8346
    acidpope
    The 650 stays with it in the 0-60 range because of it’s higher low end torque. In the long haul though, the zx-6r puts out about 35-40 more bhp and after the lower speeds will pull away fast. If you’re new, stay away from in-line four powered bikes.
    July 5, 2008 at 1:13 pm #8378
    The 650R is a chef’s knife. Sharp, powerful, and will cut you if you don’t respect it.
    The ZX-6R is a surgeon’s scalpel. It is extremely sharp, does exactly what you tell it to, even if that is just an unintended movement, and will do very serious harm if you don’t know how to handle it right.
    By comparison I’d call a 250R a nice camping sheath knife. It’ll do anything you ask of it, it still takes some respect and control, but it is weighted well enough to comfortably handle most anything with it without cutting you.
    If you don’t work with knives on a regular basis, this comparison might be useless to you :P
    July 6, 2008 at 12:15 am #8404
    StarfoxXIII
    I get it. I gues im looking for more teck info I understand that the ZX-6r is more powerful im just wondering what makes it more. Does anyone know any good sites that get very specific with the bikes.
    July 6, 2008 at 2:14 am #8410
    Dyno charts from Two Brothers racing to compare stock vs slip on performance:
    http://www.twobros.com/Cust_Service/Dyno_Charts/index.htm
    first lets look at the Ninja 650R
    http://www.twobros.com/Cust_Service/Dyno_Charts/Ninja650R_2006_hp&torq.pdf
    Here we see two things, a fairly steady climb on the hp, with only really a 10 foot pound torque gain through the entire powerband. So she’ll tug harder up to about 7k, then the torque drops off (notice the hp doesn’t, that is because hp is a factor of torque AND rpm). This means it will accelerate slower above 7k than it did below, but it will still have plenty of power to keep you moving. Also notice the scale, We are now talking about torque in excess of 35 pounds throughout the entire usable range. More than double that of the ninja 250.
    Lastly, lets look that the ZX-636R
    http://www.twobros.com/Cust_Service/Dyno_Charts/KAW_05_dualvale_zx636r_torq&hp.pdf
    On the torque side of things, it climbs to a similar peak, from a similar low, but it is almost always above 40 pounds. The 650R only makes 40+ pounds for 3000 rpm, the 636 holds it for 7000.
    Move over to the hp chart, and we see it is already making the 650R’s peak hp at just past half way through the rpm range. It climbs a similar slope, but keeps going to almost twice the power of the 650R.
    But it isn’t just about power. Honestly, power is only a small part of what makes the bike hard to handle. “Handling” is a bigger issue. The ZX-6R turns in much sharper and faster than the 650R. Most cars take 2.5 turns of the steering wheel to reach full lock. So you have two and a half turns to accurately get the wheel where you want it. Supersports are like taking that making it only 1.5 turns, Suddenly every movement on the wheel has that much more of a magnified effect. You have to be smooth and subtle in your controls, over corrections are dangerous.
    Then you add in the brakes. Just like the quick throttle can land you in trouble, so can powerful brakes. Go into a corner too fast, panic and grab your brakes to slow down, the bike will “high side”, that is, stand up and throw you off it.
    July 6, 2008 at 4:32 am #8420
    StarfoxXIII
    This is a lot of help like I said I don’t know what im getting now going to what one more summer.
