- This topic has 7 replies, 7 voices, and was last updated 16 years, 4 months ago by
Munch.
More About Materials
June 26, 2010 at 5:09 am #4070
PinkEagles
Participant1) Are leather jackets or textile jackets more abrasion resistant?
2) There’s such a variety of materials used in textile jackets, which are good to look for/ have the best abrasion resistance?
June 26, 2010 at 5:14 am #27218briderdt
Participant1) Yes, leather is more abrasion resistant than textile, but still, you want to look for 1.4mm thickness or so.
2) Cordura is the industry standard.
June 26, 2010 at 1:53 pm #26883WeaponZero
Participant1. Leather is more protective but when it comes to climate control it has its downsides. Basically with leather you need a different jacket for every type of weather condition you plan on riding in. You need one perforated one for hot weather, one solid one for cooler/cold weather, and even with vents they suck in hot weather if you can’t keep moving at a brisk pace.
2. Cordura is the industry standard but not necessarily because it’s the BEST, more that it offers a good compromise of cost, weatherproofing, and protection. Textile jackets’ strengths over leather is that they’re more comfortable (though this is a matter of personal opinion), can be made to be fully waterproof (leather is not waterproof), and one single jacket can be made to cover every single riding condition imaginable.
I own 4 jackets for varying weather conditions:
My main jacket is a Scorpion EXOwear Stinger leather jacket, which is a perforated sport-style jacket that is made to fit your body like a second skin. As I said it is perforated so it is made for riding in warm/hot weather, but because of the way perforated leather works it is impractical to use when commuting in the city because it depends on the airflow you can only get from moving at speed to keep you cool. Otherwise you’re sitting there in 90 degree weather in a heavy leather jacket and dying of heat.
My “commuter” jacket is a Speed & Strength Moment of Truth mesh jacket that I wear for commuting to and from work in warm/hot weather. Because of the nature of the way mesh jackets work, you don’t need to be moving at speed to keep cool in hot weather, so you’re fine when you’re stuck in traffic. They do generally sacrifice protection over conventional textile jackets but as long as you’re sure to get one that still has ballistic nylon textile panels in the high impact zones this shouldn’t be an issue. It did come with a waterproof liner but I never use it as it is not breathable so it is extremely uncomfortable to wear.
For days when the forecast is calling for rain I wear my soon-to-be-replaced Teknic Freestyle textile jacket. Honestly the thing sucks. I hate the way it fits and I hate the fact that the sleeve adjusters don’t keep adjustment. The only reason I even wear it at all is because it’s still a waterproof armored jacket. It’ll soon be replaced.
For cooler/colder days I wear a Scorpion EXOwear All-In leather jacket which is a solid black leather jacket that has zippered vents you can open and close (which do very little because they are small and not enough of them). This is the jacket I wear most often in the early spring/late fall because with the liner in it keeps me comfortably warm even into the 30s. I also use it as a casual wear jacket because, well, it just looks cool and you can get away with it since it’s just a plain black leather jacket.
If you’re on a budget and you can’t afford to buy multiple jackets then your best bet would probably be to buy a well-ventilated textile jacket that has a removable thermal liner of some sort, such as the Icon Contra or the Scorpion Burnout. And even if you do have money to burn on multiple jackets, if your regular riding route includes a lot of city traffic then a jacket such as this will still be a staple in your collection. It’s not a bad place to start.
June 26, 2010 at 4:40 pm #27219eon
Participant1) Depends. I think in general yes, leather does a better job but it all depends on the fabrics involved (both leather and textile). There are some hi-tech textiles out there like SuperFabric that claim 4x abrasion resistance of leather. This is expensive stuff though and is only used in impact areas on expensive gear.
2) Look at the denier number for Cordura products. Higher numbers are better. 500 is about the standard with some offering higher numbers in the impact zones. Avoid polyester as that melts in the high temperatures generated during a slide. Some jackets though will have a polyester outer layer as I think that helps with waterproofing, but should have a Cordura inner shell for protection. Not always easy to get all this information though.
The route I have taken is to have a separate Gore-Tex rain jacket that I wear over my motorcycle jacket. This is wind/water proof and allows me to wear a light (expensive!) mesh jacket underneath. I am very happy with this and would probably have bought a leather jacket if I’d planned on doing this. Trying to find one jacket that does it all is near impossible. The climate where you live will go a long way to determining what kind of jacket you should look for.
June 26, 2010 at 9:17 pm #27221Jeff in Kentucky
ParticipantYou can now buy a leather jacket with a waterproof liner, but the price is high and you will sweat a lot in the summer:
http://www.aerostich.com/aerostich-suits/transit-jacket-1.html
The lower budget alternative, cooler in the summer, is to buy a textile jacket with an inner liner and sweaters added for colder weather, and add a waterproof outer jacket when it rains for both dryness and more warmth. This is what I chose, after trying a few on and looking at the armor they came with:
http://www.olympiamotosports.com/mensbonneville/mensbonneville.htm
June 27, 2010 at 2:18 pm #27223Munch
ParticipantNot sure why you would feel the need to get a “water proof” liner. It amazes me that folks still insist that leather cannot be weather proofed. I guess coming from a horse back riding back ground and wearing leather a good majority of my life in one form or another and forgetting some never do.
Leather is easily “water proofed” through quite a few methods and their are companies out there even specific to motorcyclists. You can find silicon sprays…. Conditioning “rubs” and even go as simple as CampDry from your local Wally World.
Really makes no sense to me to say that leather is highly abrasion resistant but “Oh go don’t get it wet it will ruin it”……what!?Granted it costs a touch more…and especially if you throw a very popular brand name on it. And yes…. if your day is more spent more in air conditioned buildings then outside it will make you hot especially compared to mesh … some textiles out there are just as hot…but water is not going to ruin it like it’s some kind of alkaseltzer material.
http://www.leathertherapy.com is a good place to look. Just click in their motor sports section
Other places to look are any equestrian store or shop. Or “country/western” store.July 1, 2010 at 12:37 am #27277gitchy42
ParticipantReally it is just easier to get a waterproof textile jacket, textile jackets are USUALLY more versatile and you don’t have to ‘take care’ of a textile jacket the way you do leather.
I’ve had a lot of leather boots that I have taken care of that I wore the sole out on and a lot the I didn’t take care of where the leather started cracking or shrinking. If you get leather you just have to know how to take care of it, and be willing to do the work. It isn’t hard, but it hast to be done.
Also, now there are some textile jackets that are being described as ‘almost’ as strong as leather, and one that I was told by a salesman that is stronger than leather. But he was a sales weasel….anyways, just a thought.
July 2, 2010 at 10:43 pm #27312Munch
ParticipantYup…. as you say …to each their own. Just felt the need to add some info so as to not mislead folks into thinking leather cannot be waterproofed or be a wasted option for “protection”.
