- This topic has 2 replies, 3 voices, and was last updated 17 years, 1 month ago by
WeaponZero.
Hyosung GT25R
October 6, 2009 at 1:47 am #3486
eric the red
ParticipantHas anyone had any problems with the GT250? i have had the electric dash die on me and i have been told it will cost $1500 to replace it. It is only 2 years old.
October 6, 2009 at 5:33 pm #22692stu
Participant1500$? for that I’d remove it myself and find the loose wire/fure and see whats going on. $1500 sounds like a joke. unless its physically damaged I’d check for loose/broken wire, bad fuse, failing that I’d check the pcb for dry solder joints.
October 6, 2009 at 8:04 pm #22693WeaponZero
ParticipantThis is a common problem with Hyosung motorcycles and one of the reason my friend (who is a motorcycle technician)’s dealershop stopped sellign Hyosungs. This was a VERY common warranty issue with them and the dealers were having a hard time obtaining the parts needed to fix it. And no, it’s not a loose wire/fuse, stu.
