- This topic has 4 replies, 4 voices, and was last updated 16 years, 11 months ago by
XRayHound.
how many is too much
December 5, 2009 at 3:47 am #3602
Michael T
Participanthow many miles are to many for a used bike? and how long do motorcycles usually run? like 100k or so
December 5, 2009 at 5:30 am #23604briderdt
ParticipantWith proper maintenance, a bike should last well into the 100K’s. Also, those in the know have said they’d be very hesitant to buy a used bike older than 10 years, especially a sport bike.
December 5, 2009 at 9:23 pm #23611A
ParticipantDurability highly depend on which bike, engine configuration and serive performed by previous owner(s).. usually, thumpers, single cylinder engine would require more frequent cylinder rings replacement than twins, triples or four cylinder engines.
December 6, 2009 at 3:14 am #23616Michael T
Participantalright thanks fellas
December 9, 2009 at 8:48 am #23654XRayHound
ParticipantFor which there is no easy answer. Motorcycles are comparatively easy to maintain, but many otherwise competent mechanics regard them as black magic, so it may be done and it may not be done. Bikes also tend to age faster than they rack up miles, simply because of their nature. Cages get to the 100K mark pretty fast, bikes don’t often even live that long, for reasons entirely unrelated to the wear that mileage is meant to be indicative of, to the point where 30K sounds like a million when it’s tacked onto a bike ad.
But the fact of the matter is the bikes have the same… or better… engineering than the cars that last 300000 miles, and condition and existence of maintenance records is always but always > indicated mileage, regardless of age (the exception being bikes with a known notorious failure point, like the cam chain in pre-gear-driven-cam Honda V4s). Unfortunately the only way to tell a bike’s condition is with a competent inspection, which is something you can only do from experience, and since this a site geared toward beginners that’s not quite so practical.
So with that in mind I would recommend a cutoff point of 20K for a used bike purchase without the benefit of an experienced hand and eye. -
