- This topic has 2 replies, 3 voices, and was last updated 16 years, 9 months ago by
briderdt.
Help problems with 2008 ninja I just purchased
January 28, 2010 at 9:25 pm #3678
speedmike
ParticipantHelp… I recently purchased a 2008 Ninja 250r with 1400 miles but when I got it there were no signals. I purchased 2 sets of LED’S (motrax from cycle gear) and installed them but the wont blink at all no flash they just stay on…Help me please. Any ideas?????
January 28, 2010 at 9:55 pm #24266JackTrade
Participantyour flasher relay. Since LEDs use much less power than regular bulbs, the flasher thinks they’re burned out bulbs, hence why no blinking.
I think you can purchase a relay specifically designed for LEDs that should do the trick.
January 29, 2010 at 2:30 am #24268briderdt
ParticipantYup, LED’s will flash faster because there’s much less resistance. The relay that makes it flash relies on the resistance of the system to trigger the flash. You can wire in a resistor into the circuit to take care of that. Check at NewEnough.com, I think they have them. Also at BikerHiway.com and CustomDynamics.com.
