- This topic has 2 replies, 3 voices, and was last updated 16 years, 3 months ago by
gitchy42.
Helmet Size
July 11, 2010 at 6:56 am #4097
PinkEagles
ParticipantHow snug is a helmet supposed to be? I’m right between being an extra small and a small. The X small is really snug, and makes me feel a little claustrophobic. The small feels better, but I’m worried it’s too big.
July 11, 2010 at 3:51 pm #27441Jordan S.
ParticipantI hear… cant remember where but It needs to be snug enough not to be rolled off your head if someone were to pull it forward from the front or the rear. It definitely needs to be snug but remember that the foam will shape to your head. So it needs to be tight but image if it was a little looser. Go with tighter over looser.
Different makers make different sizes so if your buying over the internet go to a dealer and try out that maker and the different sizes and ask the associates there to double check too!
For example I am a Medium-Large for Scorpion’s Exo-400.
Doesnt mean I will be a medium-large in a Shoei though.
When you have it on, have someone give it some good yanks to try to get it off. It shouldnt come off easily or at all (of course you want it to come off just not in an accident).
Go full-face too.
And a 600$ helmet doesn’t necessarily mean it is better than a 70$.
http://roadsafety.mccofnsw.org.au/a/11.html on protective clothing.
http://pages.cs.wisc.edu/~john/vfr/hurt.html STATISTICS and some good info about the helmet I think.
July 15, 2010 at 11:42 pm #27526gitchy42
ParticipantWhen you have the helmet on and the strap tight, reach back and push up on the back of the helmet, it should roll forward a little, but not enough to block your vision. Then push up on the chin, again it will roll a little, but not much. Next grip the helmet with a hand on each side, and try to twist the helmet right and left, without moving your head, preferably infront of a mirror. Again it will move, but it shouldn’t move much, and when it move your cheeks should get pulled along with it. If a helmet passes those tests, see if the store minds you wandering around the store with it on for about 15-mins, sometimes a helmet will feel right at first, but after a while you get a headache, which is bad when you are on two-wheels.
The instructor in my basic course suggested that if you are buying a ‘better’ brand helmet, they usually have removable/replaceable cheek-pads, so you should first try them on with the cheek pads out to pay more attention to the fit around the crown of your head, then when you have that fitted find the right cheek pads to go with it. Also the SHAPE of a helmet varies depending on manufacturer and style of the helmet, so depending on the shape of your head some helmets will fit better than others.
If you want something visual, there are some good videos on youtube, here are a couple that I have found.
Proper Fit by The Helmet Center
Helmet Fitting by JPCyclesIf you look at The Helmect Center’s channel, they have reviews of different helmets too.
