Helmet lock question
  • This topic has 9 replies, 5 voices, and was last updated 18 years, 5 months ago by Budd.
  • June 30, 2008 at 3:37 pm #1635
    Budd
    On my Ninja 250 the helmet lock is placed so that if I use it the helmet will rest on the exhaust pipe. This can’t be good for the helmet. Is this only to be used for storage or will it not affect the helmet to rest there?
    June 30, 2008 at 3:57 pm #8094
    hrm… what year ninja? My buddy uses the helmet lock on his 2007 ninja and I don’t think it rests on the exhaust pipe… The 2007 and older ninjas having the dual exhaust system that is… How are you locking the helmet position-wise that is? And I guess, you could try to check under the seat if there’s some kind of hook where you can put your helmet rings over.
    June 30, 2008 at 4:48 pm #8097
    AaronMerlot
    I made the mistake of not using the lock correctly the first few weeks, so my helmet hung very close to the pipe also. Now I know that the metal “D'” ring is what gets locked under the seat in the hook on the bike. That is what my problem was. Hope it helps.
    June 30, 2008 at 6:14 pm #8103
    Jiriki
    if it is the 08 250, you only have an exhaust pipe on one side, so use the other side helmet lock :P
    June 30, 2008 at 7:36 pm #8107
    Budd
    It is an “05 with the duel exhaust. I hang it from the D ring facing backwards and the lower edges of the helmet rest on the exhaust.
    “I am the best I am at what I do, and what I do ain’t nice.”-Wolverine
    June 30, 2008 at 8:55 pm #8114
    bam37
    how do you use the helmet lock? pic’s?
    June 30, 2008 at 10:47 pm #8117
    Is the side where the D-ring is closest to the top of the bike? Not sure what facing backwards really means. For my shoei, if I fasten the d-ring side of the helmet to my sv650s helmet fasteners under the seat, the visor points to the rear of the bike.
    June 30, 2008 at 10:48 pm #8118
    What bike? My buddie’s 07 ninja250 has a lock mechanism on the rear left side of the bike. My bike has 2 fasteners under the rear seat. Not sure what other makers do.
    July 1, 2008 at 5:41 pm #8157
    Jiriki
    08 250R has two fasteners under the rear seat as well…
    July 2, 2008 at 2:29 pm #8203
    Budd
    According to this thread, there is a trick with balancing it on the rear peg to keep it off of the muffler: http://forums.ninja250.org/viewtopic.php?p=594932#594932
