Helmet fit
Helmet fit
  • This topic has 9 replies, 7 voices, and was last updated 17 years, 8 months ago by Clay Dowling.
Helmet fit
  • March 3, 2009 at 11:56 pm #2579
    mjolnir85
    I have just today bought a new Shoei RF 1000 Nightwing helmet
    it’s great and the fit is perfect, but the padding is a bit too snug.
    Now I’m told that it should loosen up with wear and that you want the
    helmet to be as snug as possible to begin with.
    The only worries I have is that with the padding supposedly packing in,
    will I have considerable amount of freedom in space?
    After wearing the helmet for 15-30 minutes, I found that my temples and
    cheeks were sore.
    Should I just wear it out and let the helmet settle?
    Or is there a problem with size, am I wearing too small?
    March 4, 2009 at 12:34 am #16877
    Sangria7
    The helmet fitting guidelines:
    http://www.hjchelmets.com/proper_fit.htm
    Bottomline they are always very tight brand new and it will take several hours of wear even weeks to break it in properly.
    March 4, 2009 at 1:02 am #16879
    SantaCruzRider
    (Disclaimer-I have no experience with this helmet) – but, a helmet should not be leaving your temples sore after only 15 minutes. Most helmets will fit a bit snug when new, but it they are creating hot spots after this short a time, it’s likely either too small or the wrong shape for your head.
    Personally, I’d take it back to at least see if they could switch out the padding (not sure about this model, but many have different thicknesses available).
    March 4, 2009 at 1:56 am #16881
    mjolnir85
    I see, well I called the dealer to ask about the issue and he also said that it is most likely
    because it hasn’t been broken in yet but offered that he could see if there was a problem
    if I came back in with it.
    It’ll be a hassle to go back for me right now, so I’ll try wearing it in and if that doesn’t work
    I’ll definitely take it back. He does tell me there are pads to switch out, but only for the cheeks…
    Hopefully, the padding will flatten out a bit?
    March 4, 2009 at 5:16 am #16884
    nau_lax21
    helmets are supposed to fit really snug at first. give them some time to break in. sounds like yours may be a bit too tight. if there’s a store around you that specializes in mc helmets, try them first. i know of 2 in the phoenix az area but thats probably not helpful to you at all.
    check online for a helmet-specific store, they will be the most helpful in finding a helmet that fits your head right.
    just a warning tho, they will likely be more expensive than online
    March 4, 2009 at 1:16 pm #16885
    DK
    I have the same helmet and had the same issue that while the large was too sloppy to consider but the medium was very snug. It took about two weeks for my head to feel just right inside the helmet.
    That said, did you try on other helmet brands to determine if maybe your head shape would be better suited for a different manufacturer?
    March 4, 2009 at 6:00 pm #16888
    mjolnir85
    The HJC and Icon fit a bit loose, however last night I tried keeping the helmet on
    for about an hour, and it wasn’t so bad minus the fact that I was getting hot from wearing
    it inside the house! Of course, I flipped the visor up and the heat dissipated as wel. :D
    I think the size will fit nicely once I break them in, I suppose I was just a little anxious
    from picking up my first helmet!
    Thanks everyone :)
    March 4, 2009 at 11:15 pm #16901
    PhilUp
    Make sure the helmet is for your head shape. You can only know this by trying on a variety of helmets from different manufacturers. My helmet fit snug, and I had a little pressure on the center of my forehead. I had headaches for the first 2 weeks or so til the helmet was broken in. Now it fits and feels perfect and best of all, no headaches!
    March 12, 2009 at 11:47 pm #17014
    nau_lax21
    this should help
    March 13, 2009 at 3:19 pm #17021
    Clay Dowling
    I’ve always been a little worried about my helmet, because I’m wearing a XXL, but per the video I have the right size. It pushed my cheeks in slightly, and there’s no risk of getting my fingers between my head and the helmet. Even my balaclava is a tight fit and gives me a headache after about an hour.
