Fork lock
Fork lock
  • This topic has 2 replies, 2 voices, and was last updated 17 years, 6 months ago by japac1.
Fork lock
  • May 8, 2009 at 1:18 pm #2796
    japac1
    Ok: Big NOOB question: I rode to work for the first time today and wanted to lock the front fork. I have a Virago 250. I assume that all fork locks are somewhat similar. Anyway, when I lock the fork, the front wheel is turned too far to the right and it seems the bike is not balanced well. Is that how it’s supposed to be? Thanks
    May 8, 2009 at 1:47 pm #18253
    To use your fork lock, you should be using your side stand and turning your handlebars in the direction of your side stand. I.e. if your side stand is on the left (which it is), turn your handlebars all the way to the left and lean it over on the stand, then set the fork lock.
    If you cannot do this when setting your fork lock, something’s wrong.
    May 8, 2009 at 2:06 pm #18254
    japac1
    That’s what I thought. I found a manual online (since my OP): Turn handlebars all the way to right, and then slightly to the left, as you lock the fork. But, it still keeps the handlebars (I feel) turned too much to the right. Thanks
