- This topic has 6 replies, 5 voices, and was last updated 18 years ago by
Matt.
crazy wind under my HJC-FS10
November 4, 2008 at 5:17 pm #2319
Phil
ParticipantFirst off thanks for the review .. I bought it due to what I read here!
Now my problem… I have crazy wind between my face and the visor it comes in from the bottom opening and its making my face hurt and my nose drop.
Any recommendations ?November 4, 2008 at 10:32 pm #14582Ben
ParticipantMine came with this little insert u can put at the bottom of the helmet to help block some of the wind, does yours have that?
~Best Beginner Motorcycles AdminNovember 5, 2008 at 2:58 pm #14598Clay Dowling
ParticipantI get a lot of wind under my HJC helmet as well. On a warm day I find it quite pleasant. On these cold fall mornings in Michigan I find it invigorating, in the same way that ice fishing is invigorating. Once the weather turned cold I picked up a balaclava, and life got a lot better. It kills the heavy wind and keeps me warm in general. You might give the balaclava a try if the wind is bothering you to much. Mine stops most of the wind from coming under.
November 5, 2008 at 5:04 pm #14601Phil
ParticipantBen, mine has the chin guard too, but i tried with and without and it does not seem to make a difference. In this cold weather the windblast even makes my eyes water (not safe!!).
A baclava will keep me warm but i really would just like to reduce that wind!
I have a windshield but usually ride without it. How does not one else have that problem? maybe its my riding position? It is probably made for sports bikes.~phil
November 6, 2008 at 4:37 am #14617Loki
ParticipantI have that problem to and it truly does suck.
November 7, 2008 at 3:53 pm #14671Phil
Participantnoise level is ok its actually quite pleasant … also no lift … really the only problem is that cool wind to my forehead and nose.
November 7, 2008 at 6:00 pm #14677Matt
ParticipantThey make neoprene neck guards you can put around the base of the helmet that pretty much seals the underside. You might want to look for one of those (my local dealership sells then for $20).
Also, try various head angles and seating positions. Depending on how I sit adn how I tilt my head it makes a huge difference on the amount fo wind coming up my helmet.
“The two seconds between ‘Oh S**!’ and the crash isn’t a lot of practice time.” -
