- This topic has 3 replies, 3 voices, and was last updated 18 years, 1 month ago by
Ogre.
CC Ratings for Suzuki Bikes
October 2, 2008 at 5:55 am #2185
Ogre
ParticipantI have been comparing Bikes and trying to figure out which is right for me. I was looking at Suzuki’s and am having trouble comparing them. The things I am compairing are CC’s, weight, and length. I cannot figure out which one of these things can be translated into power or CC’s. I imagine it relates to compression ratio, but am mildly confused. Stupid metric, all that logic has no place in America! Anyone know the CC rating for The Suzuki Boulevard bikes?
Here is the full specs for the S50
2008 Boulevard S50
Specs
Engine: 4-stroke, liquid-cooled, OHC, 45° V-twin
Bore Stroke: 83.0 x 74.4mm
Compression Ratio: 10.0 : 1
Fuel System: Front: MIKUNI BDS36 Rear: MIKUNI BS36
Lubrication: Wet sump
Ignition: Electronic ignition (Transistorized)
Transmission: 5-speed constant mesh
Final Drive: Shaft drive
Overall Length: 2250 mm (88.6 in)
Overall Width: 765 mm (30.1 in)
Overall Height: 1125 mm (44.3 in)
Seat Height: 700 mm (27.6 in)
Ground Clearance: 125 mm (4.9 in)
Wheelbase: 1560 mm (61.4 in)
Dry Weight: 201 kg (443 lbs)
Suspension Front: Telescopic, coil spring, oil damped
Suspension Rear: Swingarm type, coil spring, oil damped
Brakes Front: Disc brake
Brakes Rear: Drum brake
Tires Front: 100/90-19 M/C 57H, tube type
Tires Rear: 140/90-15 M/C 70H, tube type
Fuel Tank Capacity: 12.0 L (3.2/2.6 US/Imp gal)
Color: Black, SilverOctober 2, 2008 at 6:20 am #13161megaspaz
ParticipantOn suzuki’s website, the 2009 specs for that bike show 805CC. Since 2009’s the last year in suzuki’s change cycle, you can probably assume the 2008 will have around 800CCs.
around, I want it caught and shot now…October 2, 2008 at 6:29 am #13163Ogre
ParticipantI love that I was nagging about Metric when Suzuki is the ONLY manufacturer to use standard. Oh the delicious irony, pardon me while I remove my foot from my mouth. Thank you for the input!
Please don’t feed the animal.
October 5, 2008 at 7:10 pm #13162Rab
ParticipantThe number in the new Suzuki cruiser designations refers to cubic inches, so a Suzuki S40 has a 40 c.i. engine, an S50, a 50 c.i. engine, etc.
Go here to convert from cubic inches (c.i.) to cubic centimeters (c.c.):
