Best way too fix Plastic
  • This topic has 5 replies, 5 voices, and was last updated 16 years, 9 months ago by J.R..
  • February 8, 2010 at 8:14 pm #3695
    J.R.
    I cracked the plastic that runs on the far right side of the instrument panel on my ninja 250. it starts at the top by the window and goes down about 4 inches. Its not the outside fairing its the plastic panel that sits around the instrument panel. PLEASE help What is the best solvent to use
    February 8, 2010 at 10:48 pm #24460
    I’ve never used the stuff, nor have I seen it used, but I’ve seen it referred to on the SVRider board quite often.
    February 9, 2010 at 2:27 pm #24472
    BouncingRadical
    http://www.restockit.com/Flexible-Bumper-and-Plastic-Patch-Kit-(TSL3310).html?source=froogle&Bvar5=100F1&Bvar6=100F1&Bvar7=100F1
    February 9, 2010 at 4:48 pm #24474
    SantaCruzRider
    The instrument panel should fix well with a 2-part epoxy — it comes in black so no issue.
    This is different plastic from the fairing, which is an ABS and responds well to ABS cement (the kind plumbers use on ABS pipe).
    February 10, 2010 at 12:06 am #24484
    Ixecapade
    E6000 is a pretty good industrial strength glue. not sure how well it does as far as ‘clear’ but if you don’t smear it all over the place its no big deal.
    February 10, 2010 at 2:02 am #24490
    J.R.
    thanks for the help and what kind of 2 part epoxy? can you throw out some brands, some examples will help
