- This topic has 2 replies, 3 voices, and was last updated 16 years, 10 months ago by
CBBaron.
About the Suzuki DR200SE
January 15, 2010 at 10:24 am #3654
Mike
ParticipantHey everyone. Been a long time since I posted… anyway, I still don’t have a bike, but I’m still looking and will hopefully save enough cash to get one.
I’ve been thinking about a Suzuki DR200SE, but I’m a little concerned… I weigh about the same as the bike. I can’t find any maximum weight statistics for it, so anybody have any info?
Same goes for the DRZ 400SM. Any info on it’s max weight limit would be helpful. (I’m 270 lbs, btw. 6′ 5″ too, which is why I’m looking at dual-sports)
(Also, I’ll probably get something used first, this is just for down the line.)
Thanks
January 15, 2010 at 12:45 pm #24031eternal05
ParticipantYou’d be totally fine on a DR-Z400sm. You’d probably be fine on the 200SE as well, but I heartily recommend the 400. It’s a blast! Your weight is not an issue.
January 15, 2010 at 3:00 pm #24033CBBaron
ParticipantEither one will handle your weight without a problem, after all both are capable of being ridden 2 up. However you may find the DR200se is pretty small.
These two bikes are very different segments of the dual sport market. The DR200se is an inexpensive trail bike and competes with the TW200, XT250 and Super Sherpa. The DRZ has fairly advanced suspension and a water cooled engine. The SM version has sportbike tires that make it alot of fun on the pavement. Comparable bikes are the WR250x and KLX250sf.
These bikes are much taller and considerably more powerful. Ofcourse they are also more expensive.The DR650 and KLR650 are also good bikes to consider for a larger rider. These dual sport thumpers are lighter and less powerful than the 650 twin street bikes, and the seat heights will not be any problem for someone your size. They are also less expensive than the DRZ and WRX.
